HI Roger thanks for your answer,Roger Gwynn wrote: Sun Oct 18, 2026 10:53 am The reason that the seal does not fit is because it is still for a BSA not for an Ariel. As explained on the Draganfly website some gearboxes can be converted to a garter oil seal but some cannot, it depends on the year of the shell. Let me have the casting number form the shell and I can date it for you. As I said earlier the gearbox appears to be from 1938 or later but could be a collection of bits.
The valve lifter will probably work as it is and could be used as oil leaks will not be a problem but really the bush should be replaced and probably the shaft as well.
In the outer shell i can read 1/BAP E and M/3?
Then on the outer covers 3BA M / XII
Some more pics if they help
