Headlight glass
nickbenson
Headlight glass
Hi all
Could anyone tell which type of headlamp glass my 1936 vh should have originally. I have the lucas fluted glass and also the frosted bathroom window diffuser type. But I don't know which one I should fit. Help please. Cheers Nick
Dave.Barkshire
Re: Headlight glass
On my 37 I had the fluted type and in the 37 catalogue it clearly shows the glass as being fluted. 36 was very similar to 37 so that would be my guess.
http://www.arielownersmcc.com/members ... ogue08.jpg
Ariel Red Hunter VH1 1938
BSA L27 1927
Velocette MSS 1939
AJS Model 20 1953
Triumph Scrambler 900
AOMCC Member 3400
BSA L27 1927
Velocette MSS 1939
AJS Model 20 1953
AOMCC Member 3400
nickbenson
Re: Headlight glass
Hi Dave
Thanks for your reply I rather thought it was the fluted one and I much prefer it. It is also missing the small clip underneath the shell which retains the rim so I'm I bit wary of it falling out, I'll try to source one. Thanks again Nick
- Bob.Murphy
Re: Headlight glass
Available from Feked - here:nickbenson wrote: It is also missing the small clip underneath the shell which retains the rim so I'm I bit wary of it falling out, I'll try to source one. Thanks again Nick
https://www.feked.com/lucas-headlamp-be ... clips.html
Dave.Barkshire
Re: Headlight glass
Mick is missing the clip at the bottom of the lamp which holds the rim to the shell.
Maybe the Czechs can help?
http://www.vintage-replica.cz/svetlaE.htm
BSA L27 1927
Velocette MSS 1939
AJS Model 20 1953
AOMCC Member 3400
BSA L27 1927
Velocette MSS 1939
AJS Model 20 1953
AOMCC Member 3400
nickbenson
Re: Headlight glass
Hi Yes Dave you are correct it is the clip underneath that retains the rim to the shell that I seek. Regards Nick
- Bob.Murphy
Re: Headlight glass
Is it this part (or am I missing something) ??nickbenson wrote:Hi Yes Dave you are correct it is the clip underneath that retains the rim to the shell that I seek. Regards Nick
https://www.feked.com/headlamp-rim-fixing-clip.html
nickbenson
Re: Headlight glass
Hi Bob the part is like a curved flat tapered spring metal clip retained inside the underside of the lamp shell by a piece of steel wire and it has a shaped end to locate around the lamp rim and so is supposed to stay in place by its shape and tension. Regards Nick
- Bob.Murphy
Re: Headlight glass
Ah, that's a new one on me. Sorry for the confusion (I live and learnnickbenson wrote:Hi Bob the part is like a curved flat tapered spring metal clip retained inside the underside of the lamp shell by a piece of steel wire and it has a shaped end to locate around the lamp rim and so is supposed to stay in place by its shape and tension. Regards Nick
Re: Headlight glass
I am sure the Czech boys can help. The headlamp on my Square is a replica made by them and came complete with the clip you need. The one on my RH500 I made from brass strip in 1990, had it chromed and the rim hasn't come off by accident since. The rim is a good tight fit on the shell though.
Users browsing this forum: ChinniK and 4 guests
