Headlight glass
nickbenson
Headlight glass
Post by nickbenson »
Hi all
Could anyone tell which type of headlamp glass my 1936 vh should have originally. I have the lucas fluted glass and also the frosted bathroom window diffuser type. But I don't know which one I should fit. Help please. Cheers Nick
Dave.Barkshire
Re: Headlight glass
Post by Dave.Barkshire »
On my 37 I had the fluted type and in the 37 catalogue it clearly shows the glass as being fluted. 36 was very similar to 37 so that would be my guess.
http://www.arielownersmcc.com/members ... ogue08.jpg
Ariel Red Hunter VH1 1938
BSA L27 1927
Velocette MSS 1939
AJS Model 20 1953
Triumph Scrambler 900
AOMCC Member 3400
nickbenson
Re: Headlight glass
Hi Dave
Thanks for your reply I rather thought it was the fluted one and I much prefer it. It is also missing the small clip underneath the shell which retains the rim so I'm I bit wary of it falling out, I'll try to source one. Thanks again Nick
Bob.Murphy
Re: Headlight glass
Post by Bob.Murphy »
nickbenson wrote: It is also missing the small clip underneath the shell which retains the rim so I'm I bit wary of it falling out, I'll try to source one. Thanks again Nick
Available from Feked - here:
https://www.feked.com/lucas-headlamp-be ... clips.html
Dave.Barkshire
Re: Headlight glass
Mick is missing the clip at the bottom of the lamp which holds the rim to the shell.
Maybe the Czechs can help?
http://www.vintage-replica.cz/svetlaE.htm
BSA L27 1927
Velocette MSS 1939
AJS Model 20 1953
AOMCC Member 3400
nickbenson
Re: Headlight glass
Hi Yes Dave you are correct it is the clip underneath that retains the rim to the shell that I seek. Regards Nick
Bob.Murphy
Re: Headlight glass
nickbenson wrote:Hi Yes Dave you are correct it is the clip underneath that retains the rim to the shell that I seek. Regards Nick
Is it this part (or am I missing something) ??
https://www.feked.com/headlamp-rim-fixing-clip.html
nickbenson
Re: Headlight glass
Hi Bob the part is like a curved flat tapered spring metal clip retained inside the underside of the lamp shell by a piece of steel wire and it has a shaped end to locate around the lamp rim and so is supposed to stay in place by its shape and tension. Regards Nick
Bob.Murphy
Re: Headlight glass
nickbenson wrote:Hi Bob the part is like a curved flat tapered spring metal clip retained inside the underside of the lamp shell by a piece of steel wire and it has a shaped end to locate around the lamp rim and so is supposed to stay in place by its shape and tension. Regards Nick
Ah, that's a new one on me. Sorry for the confusion (I live and learn :D ).
Re: Headlight glass
I am sure the Czech boys can help. The headlamp on my Square is a replica made by them and came complete with the clip you need. The one on my RH500 I made from brass strip in 1990, had it chromed and the rim hasn't come off by accident since. The rim is a good tight fit on the shell though.
