Timing pinion left hand nut
- Leejm
Has anyone got the above. draganfly is out of stock many thanks lee
- Leejm
Re: Timing pinion left hand nut
I will try him in the week.
johnwalsh
I bought the same thing from Drags two weeks ago and had to send it back, It was too small. Then said they were unable to supply, where do they get this stuff made!
1958 Huntmaster
1960 Matchless G12
1958 AJS 18s
1960 Matchless G12
1958 AJS 18s
Surely there must be a obscure bike like BSA/Triumph/Norton/AJS -M-/Brough/James/Excelsior ....that uses the same nut ? Huh?
- Leejm
I would of thought so to. I may pop over to supreme motorcycles on Friday there shop is only a few miles away and see if they got anything.
howard.aris
Did you find a timing pinion nut ? I have a LH 9/16 -20 tap - I think that is the right size - if so, could make for you
- Leejm
No still not got one and yes that is the correct thread size. Many thanks Howard lee.
- Richard Kal
From memory, the crankshaft timing nut on an A10 is 9/16 x 20 tpi LH.
Richard
Richard
howard.aris
Lee, I don't have any fancy steel to make this nut - will A4 stainless be OK ? it is a pretty tough material. Howard
