Timing pinion left hand nut
Leejm
Post by Leejm »
Has anyone got the above. draganfly is out of stock many thanks lee
dave.owen
Re: Timing pinion left hand nut
Post by dave.owen »
Have you tried John budgen
Dave
Leejm
Post by Leejm »
I will try him in the week.
johnwalsh
Post by johnwalsh »
I bought the same thing from Drags two weeks ago and had to send it back, It was too small. Then said they were unable to supply, where do they get this stuff made!
1958 Huntmaster
1960 Matchless G12
1958 AJS 18s
Surely there must be a obscure bike like BSA/Triumph/Norton/AJS -M-/Brough/James/Excelsior ....that uses the same nut ? Huh?
Leejm
Post by Leejm »
I would of thought so to. I may pop over to supreme motorcycles on Friday there shop is only a few miles away and see if they got anything.
howard.aris
Post by howard.aris »
Did you find a timing pinion nut ? I have a LH 9/16 -20 tap - I think that is the right size - if so, could make for you
Leejm
Post by Leejm »
No still not got one and yes that is the correct thread size. Many thanks Howard lee.
Richard Kal
Post by Richard Kal »
From memory, the crankshaft timing nut on an A10 is 9/16 x 20 tpi LH.
Richard
howard.aris
Lee, I don't have any fancy steel to make this nut - will A4 stainless be OK ? it is a pretty tough material. Howard
Users browsing this forum: No registered users and 50 guests
