Centre crank oil seal removal - help!!!
The Arrow's getting new crankshaft seals. The strip-out's gone fairly well until the very last item - the centre oil seal.
The workshop manual says that after removing the bearing the centre oil seal can be easily removed with a drift and mallet....
Well, all I've succeeded in doing is knocking the centre out of the seal - it's an original-type double seal and there is no metal lip at the front or back.
I seem to be left with a steel-backed rubber cylinder that it's impossible to get any purchase on.
I can't be alone in having this problem - anyone got any advice? All I can think of so far is trying to burn it out, or maybe burn off the rubber, heat the steel backing to red-heat and jam something under it to collapse it.
Or possibly get the rubber off the steel and put a couple of weld blobs on it to use to knock it out.
Anyone got any better ideas - please!
Mick D
Re: Centre crank oil seal removal - help!!!
Post by Mick D »
A photo would help, how about a blind bearing remover? I have a similar set that's got me out of a pinch several times in the past:
https://www.amazon.co.uk/Moendergo-Bear ... hdGY&psc=1
Ivor Collins
Post by Ivor Collins »
The one-piece seals can be difficult to remove.
The last one I did required the use of a die grinder and a steady hand to cut 90% through the steel case before peeling it out like a sardine can lid😵‍💫
Ivor Collins
Center seal
Seal removal in progress!
I seem to remember that I used a small screwdriver blade hammered in between the outer casing and the case that effectively reduced the diameter of the outer so that something bigger could be used to collapse it.
