Project 1934 VG 500
AlbertR
Project 1934 VG 500
Post by AlbertR »
Dear all,
This post is a continuation from my presentation post, you can read it here for more context: viewtopic.php?p=108806
So this last week i got a sturdy wooden box delivered!
Including lots of spares too.
I want to thank you all for your advises prior to making the decision, specially to Vincent.
I received the bike is in a semi-restored state, currently assembled just to present all the elements, but all the nuts and bolts are loose. Few things need painting and finishing off, and adjusting.
There are a few things which you have pointed out that are wrong, including:
- Mudguards are not correct
- The oil tank fitted is from 1935
- May too much chrome
- The handlebar clamp is upside down
- The combined lifting handle/rear mudguard stay is upside down and there are two stays missing
Before buying the bike i had several concerns, the main one being that the bike seemed to have a BA gearbox that seems an update, and does NOT have a tank operated gear change, or any signs of it on the fuel tank.
However, quoting from the club registrar (thank you for that Simon), providing him the Framenr: Y5326 and block GA1588,
From the details in the despatch book, those details produce a matching-numbers VG despatched in May 1934 – which ought to be hand-change.
Foot change was an option in 1934 and was standard on the Red Hunters; they would have (and did) record foot-change where it was invoked as an option.
Moreover, I found this picture from a 1934 VG on the forum archive, which made me decide maybe it was a good investment!
I also have the pictures before the restoration, but i need to digitalise them in better quality.
AlbertR
Re: Project 1934 VG 500
Post by AlbertR »
So, today I started working on the bike a bit, disassembling the fuel tank for painting and also the transmission case.
And here comes the first questions for you, if you dont mind :)
- Is the fuel tank original?
- I am also in the process of finding somewhere in the forum how the lines should be painted for that model. I guess the correct way would be in black on the side like the picture of 1934 model vg from the forum? But i'll need some template.
AlbertR
Post by AlbertR »
Found this image in this thread, looks promising.
viewtopic.php?t=4764
Tanks were painted by hand and eye and could vary by as much as an inch on each side of the tank! Your gearbox is a BA, just a foot change version rather than hand change, a common mod.
Roger Gwynn wrote: Wed Sep 02, 2026 11:10 pm Tanks were painted by hand and eye and could vary by as much as an inch on each side of the tank! Your gearbox is a BA, just a foot change version rather than hand change, a common mod.
Which in turn would imply the tank is not original given that if I recall correctly, that bike wasn't dispatched as a foot change machine. The original tank would have had the hand change bracket.
I'll have another look tomorrow when I do your certificate Albert!
admin
Post by admin »
Albert
Please see the note in this topic about using links to images that are hosted elsewhere: viewtopic.php?t=193
Can I ask you to please replace the image links that you've posted with the original images?
(Over time a lot of things on the web change and disappear. As an example we already have problems with images from photobucket that were used in posts and are now unavailable.)
Thanks
