KH TWIN OIL MODIFICATIONS
philip.butcher
Post by philip.butcher »
Hi all i seem to remember reading about a modification to the oil feed to the cylinder head on the 500 twins can anybody enlighten me as to what and why? please,. also burman gear levers my kg has a solid lever with a polished end 7" between centres and no provision for a rubber , i wonder if this is a wd lever ? what length lever should the cp gearbox use as i have various length ones to use , thanks in advance philip
paul.jameson
Re: KH TWIN OIL MODIFICATIONS
Post by paul.jameson »
Which year KH are we talking about? The oil modification is, from memory, 1956 onward, but only required because they cocked up the oil supply to the rockers with a mod in 1955. Earlier models are no problem from this point of view.
philip.butcher
hi paul thanks for the reply my kg is a 1950 model philip
adrian.hannam
Post by adrian.hannam »
Here are a couple of posts about this subject, is this what you are looking for?
http://forum.arielownersmcc.com/viewt ... f=4&t=6804
http://forum.arielownersmcc.com/viewt ... f=4&t=8351
Editor "The Horse's Mouth" Australia
philip.butcher
Hi Adrian, thank you for the links ,that was what i believe i read in the cheval der fer in the distant past regards philip
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
