KH TWIN OIL MODIFICATIONS
philip.butcher
Hi all i seem to remember reading about a modification to the oil feed to the cylinder head on the 500 twins can anybody enlighten me as to what and why? please,. also burman gear levers my kg has a solid lever with a polished end 7" between centres and no provision for a rubber , i wonder if this is a wd lever ? what length lever should the cp gearbox use as i have various length ones to use , thanks in advance philip
Re: KH TWIN OIL MODIFICATIONS
Which year KH are we talking about? The oil modification is, from memory, 1956 onward, but only required because they cocked up the oil supply to the rockers with a mod in 1955. Earlier models are no problem from this point of view.
philip.butcher
hi paul thanks for the reply my kg is a 1950 model philip
- adrian.hannam
Here are a couple of posts about this subject, is this what you are looking for?
http://forum.arielownersmcc.com/viewt ... f=4&t=6804
http://forum.arielownersmcc.com/viewt ... f=4&t=8351
philip.butcher
Hi Adrian, thank you for the links ,that was what i believe i read in the cheval der fer in the distant past regards philip
