Front fork suspension caps
PaulHarding
Post by PaulHarding »
The original suspension top caps are seemingly unavailable.
I have used the caps from Right Guard deodorant spray cans (small cap) which require a hole to be drilled allowing the top thread to peak through, held in situ with a spot of no nails. Can be painted if required.
Not for the purist perhaps but looks far better than the cracked ones that came with the bike !!
I'd post a couple of pics if I could find how to do it !!!!
admin
Re: Front fork suspension caps
Post by admin »
Hmmm - probably better in 2-strokes, so....moved!
Wasn't somebody 3D printing these?
PaulHarding
Thanks Roger I was under the impression that these were extinct.
Paul
They now have a 3d printer and are making all sorts of weird and wonderful things.
Vesa Helske
Post by Vesa Helske »
Hi all,
A question came up related to the ivory white colour of the front end of the Arrow on this topic. As I have an Arrow -62 with exactly the same colour but haven't been able to find a code. Does there exist a RAL code close to the one in the photo.
Thanks in advance for comments,
Vesa
From Draganfly paper catalogue, now a collectors item!
Admiralty Grey British Standard 381C range ‘Light Admiralty Grey’ ICI 0501, Rover‘Mist Grey’ is the same or Light Admiralty Grey BSC697 by PRC-DeSoto International of Shildon Co Durham +44 (0)1388 772 541
Ivory Toyota ‘White 073’; Rover ‘White 30-3738; Ford ‘Diamond White’ (Ketts code 691
Cherokee Red Ford ‘Dragoon Red’; Rootes ‘Signal Red’; Jensen ‘Carmine’ 30614
Seal Grey Rootes ‘Corinth Blue’ or Standard ‘Gun Metal or current (2002) RAF colour
Oriental Blue Fiat ‘Green 376’; Renault ‘Laguna Turquoise’
Rocket Red B.S.A. colour, see Bri-Tie motorcycles
Nutley Blue B.S.A. colour, see Bri-Tie motorcycles
Gold ICI ref D738B (matched to a sample) VW ‘Hellas Gold’ code L98A
British Racing Green
Aircraft Blue VW ‘Sapphire Blue’
Vesa Helske
Roger,
thank you very much for the comprehensive information. That will certainly help me forward!
Vesa
bh.sprint
Post by bh.sprint »
Re the plastic suspension tops. Around the 1990's some one made a batch of both suspension tops and torque arm covers in plastic, they have the letters BDG on the inside. By the time I needed some they had mostly run out but a few were available , so I made a suspension top mould in alloy and found someone who had a manual plastic injector , he made a couple of batches in off white/ creame. It wasn't a case of what is the correct colour but what colour is available. There were also some made in other colours as an experiment or to clear the injector. That's where the tops for the inspection light came from. Most of them have gone now there are just a few seconds left. Brian H.
