Hi Guys, once again need some help. I am trying to remove the sludge trap from my 58/59 HT5 (engine in situe). does anyone know what the head Hex size is. I have lots of different sockets but cant find a good fit. I have looked on the Draganfly site and can see the part number but no details.
Any idea of size type. As always any help much appreciated.
Ian
HT5 Sludge Tap
Ian.Hamilton
Re: HT5 Sludge Tap
Ian,
The HT sludge trap is the same as the NH:
viewtopic.php?t=13307
Should tell you all you'll need.
Re: HT5 Sludge Tap
There are quite a few threads on the singles sludge trap - here's another one (shows what you might find, among other things!!)
viewtopic.php?p=87690
- charles.bulloch
Re: HT5 Sludge Tap
It should be a BSW socket. I removed mine with a cold chisel (with the barrel off), the head was rounded. Single spares will sell you one with a metric head so you can use a six-sided socket in future. Fortunately with modern oils the sludge trap fills up very slowly nowadays.
Charlie
Charlie
Re: HT5 Sludge Tap
hi i have no Problem getting the sludge tap out with a good fitting six sided socket and a powerbar
Re: HT5 Sludge Tap
You certainly would not want one to come out in service but there's no need to tighten them till your eyes water The original head size is 1/4 BS. Some probably haven't been out since the warrantee ran out. The 3/8 AF and 11 MM are undersizes if you don't have a new one to replace it with. Nev
