black ariel for sale
just found this,thought someone may be interesed.It looks nicehttps://www.ebay.co.uk/itm/304984337936?hash=it ... CfFNT26QFS
Re: black ariel for sale
Hmmmm, sort of nice..
SA gearbox, and the rockers I have with my Model C look the same! Worn !
There are also 10 unrestored SQ4 in the same auction from an early 1939 plunger 4G to 1958 MKII. Most are matching number bikes but the auctioneers, as usual, are a bit confused over what an engine, frame and casting number is!
Roger , 'matching numbers' as in that huge collection from late ?
						- Paul_Linden
Here is the link to the auction:
https://www.silverstoneauctions.com/the ... -1/ipp-100
						- cmfalco
Someone has ground the face nearly flat, with the front edge now nearly a knife edge. As a result, the rocker geometry is incorrect, putting a lot of side thrust on the valve guide.Vincent.vanGinneke wrote: Fri Jun 30, 2023 8:38 amthe rockers I have with my Model C look the same! Worn !
However, it's nothing that Stellite and a grinding jig can't fix.
Vincent - 8 of the 10 SQ4 being auctioned by Silverstone Auctions have matching numbers. If you are asking about Reg's bikes, most are not matching.
