I still suspect something was wrong with the lubrication system. It is not normal to find that amount of oil in the cases. There was over one litre in there! And the Morgo hat just been overhauled and there was always a steady flow back into the tank. So the return seemed to be doing its job. My question is why was so much oil going into the crankcases, and maybe not going to the big ends where it should have been? I can’t think of a reason, but maybe one of you chaps has an idea…
Also strange was my oil pressure. Ever since the rebuild the gauge would show over 100psi on start up, and gradually decrease as the engine warmed up. But when fully at temperature, it showed 0 psi and stayed there even at speed. I put it down to a faulty gauge, which is probably not even original, but in retrospect perhaps the gauge was working and my oil pressure was indeed nil. Why would this happen, I also don’t know. Again any thoughts are highly welcome!
I did most of the checks everyone suggested and never really found anything wrong. But somewhere there was a problem.
I suppose taking the engine apart will be my project for next winter. I just don’t have the courage to do it now during riding season. I prefer to enjoy riding my 350 NH and the other bikes. I still have a very nagging oil leak on the red hunter from the timing case through the mag, but that’s for another thread
