Square four pressure problems again
john.whiting
Re: Square four pressure problems again
Post by john.whiting »
The plug could work OK by drilling either one central hole,or a number of small peripheral holes.......A central hole would be easier ,just so it was smaller than the spring ,and the spring could seat on a ledge ......the release pressure would have to be set by trial.
john.whiting
Make sure the end of the crank isnt cross drilled to flow released oil away.
GuyWalton
Post by GuyWalton »
Should look very similar to this one .
51 mk1 Areil Square Four
55 DB 500 BSA Gold Star
55 Matchless G9
67 BSA B44
06 Ducati 999R
FletchBurton
Post by FletchBurton »
Hi All,
Thanks for your replies and pics. I went and visited Lester and he has lent me the very thing. I put it on the bike and turned it over on the paddock starter... And got 80ish PSI on the gauge with oil coming past the valve in the prescribed manner. So the problem is solved. Just need to make a copy of the valve I have been lent.
Cheers,
Fletch
Paul_Linden
Post by Paul_Linden »
Guy, I thought that picture looked familiar - it’s one of my bike. :D
FletchBurton
Hi Paul,
What is the purpose of the extra bit of plumbing in Guy's picture.
Thanks,
Fletch
GuyWalton
Post by GuyWalton »
I think you sent it to me when you were educating me about the spray bar . Hope you dont mind .
55 Matchless G9
67 BSA B44
06 Ducati 999R
Paul_Linden
Guy - no problem, I’m happy to see the picture get recycled.
Fletch - the narrow copper pipe is the oil feed to a cam spray bar. It drops oil on the cam lobes.
Paul_Linden
Here is a post with more about a square four cam spray bar:
http://forum.arielownersmcc.com/viewt ... =4&t=11840
FletchBurton
Thanks, I see what it is for now.
