spark plug thread depth
charvey
Post by charvey »
Hi All,I have got an 39,iron headed and a 52 alloy headed Ariels both with 1/2" plug depth I thought that the alloy heads had a greater depth of thread but it seems not, I run them both on a mixture of NGK B6HS and B5HS spark plugs which they seem fine on but it was just the depth of the thread which I find a bit odd like I stated between iron and alloy,I did measure the threads and the alloy one is 1/2"regards Clive.
Re: spark plug thread depth
Post by will_curry »
I'd be interested to see a photo of your alloy head.
Post by JohnnyBeckett »
hi in my iron head engine i use B 6 HS or 5 plugs and in my alloy head engine i use B 5 ES or 6 plugs and the ES plug for the alloy head has got a longer thread
ian williams
Post by ian williams »
in my alloy head NH [non external pushrod tube type barrel ] it has long reach N5C plug .
charvey
Post by charvey »
Hi all,I have measured the thread depth again and it is 1/2" depth why I don't know but it is the same plug for both bikes which makes it easier enclose some photos it's on the VCH but I cannot see why that should make a difference I have a photo of the plug in place to see if the depth is the same on other alloy heads,Regards Clive.
off side
off side
off side
off side
plug in
plug in
plug in
plug in
plug out
plug out
hi how i check my plugs depth was wen i had the heads off and i could see the plug thread reach the end of the thread in the head i got a NH that come with a shorter plug that didn't reach the bottom of the thread in the head, that is wen i started to look in to the right plugs for my Ariel's
charvey
Post by charvey »
Hi John,I measured the thread with a double piece of bent wire and also when the head was off a short while ago checked the plug in the thread and saw it was a good fit in the threads and not sticking out so it is a 1/2" thread depth so Ariel's must do different depth threads in alloy heads, never having had a alloy headed Ariel before only iron it didn't strike me as odd till I ordered some recommended plugs on the forum site for alloy heads and realized the depth of the thread was different regards Clive.
BobWard
Post by BobWard »
Your plug thread is recessed a long way down.
1958 Huntmaster
1957 VH 500
1960 FB Cruiser 84
hi i can be a aftermarket head or it has had the plug hole depend for some reason :?: all the alloy heads i have use B 5 ES plugs witch are a bit longer thread than the H S plugs
charvey
Post by charvey »
Hi Bob,Thanks for the info yes for some reason or other it does seem that my head has a deeper inset than yours where the plug fits in going on your photo for what ever reason, I don't know why,the previous owner is beyond asking as he is riding Ariels in the sky but I know Chass had a dropped valve a long while ago but I see no reason to reduce the thread because of that,But as far as I know it's the same head as it's had a lot of work around the exhaust guide welding etc.,so I am sure it's the same head which has been on all the time Chass had it, thanks again regards Clive.
