Idiots guide to servicing Amal carbs
Re: Idiots guide to servicing Amal carbs
I don't think I have seen a monobloc with so much crud in it before. Getting it clean will probably be difficult but will work wonders.
It's dead fuel by the look of it. Water in the idle passages and it's usually junked. Nev
Mick D
Post by Mick D »
paul.jameson wrote:I don't think I have seen a monobloc with so much crud in it before. Getting it clean will probably be difficult but will work wonders.
This one was refurbished and is now back on the road:
Crud II.png (245.61 KiB) Viewed 792 times
Crud III.png (249.96 KiB) Viewed 792 times
The gum was dissolved in acetone and the remaining scale removed by abrasion, (DIY soda blasting). Only had to replace the gaskets and a broken throttle stop screw.
Mick D,
Your carb is now in first place in the "Crud in the carb" contest. Well done for getting it clean enough for use.
