Red hunter frame for parts wanted
JoeTurner
Post by JoeTurner »
Has anybody got a damaged red hunter frame? I need the bracket that holds the oil tank as mine is missing, it’s a 1954 swing arm frame but I presume all the swing arm ones are the same, failing that is there anyone with a bike near chesterfield that I could measure up to make the bracket. Many thanks
Mick D
Re: Red hunter frame for parts wanted
Post by Mick D »
If all the swinging arm frames are the same I have a 58 FH in bits at the moment - happy to measure up for you if it helps, is this the part you're interested in?
Oil Tank Bkt.png (144.19 KiB) Viewed 2873 times
We could draw around it and make a dimensioned drawing for you to download?
JoeTurner
Post by JoeTurner »
That’s great, now I can see what’s missing it doesn’t look that difficult to make, if you could draw around it that would be a massive help, thanks
Mick D
Post by Mick D »
Some basic dimensions from which you can mark out a cardboard template prior to manufacture:
Oil Tank Bkt Dims.png (266.67 KiB) Viewed 2782 times
Material is 2mm mild steel folded 90 degrees - width dimensions from the outside of the flange.
Total height, (1), 4 1/2"
Maximum width, (2), 1 3/4"
Minimum width, (3), 3/4"
Slot centres, (4), 3 5/8"
Slot offset, (5), 1 3/8"
Slots width 9/32"
The photo makes things look skew but the bracket is essentially a profiled 'L' section.
Pictures in this post might be useful:
http://ariel-square-four.blogspot.com/2 ... r.html?m=1
JoeTurner
Post by JoeTurner »
A big thank you to everyone. Its a big help.
Joe
