Timing pinion left hand nut
johnwalsh
Re: Timing pinion left hand nut
Howard, I've sent you a PM.
1958 Huntmaster
1960 Matchless G12
1958 AJS 18s
1960 Matchless G12
1958 AJS 18s
- Leejm
That will be great thank you Howard that's very helpful of you.
- Leejm
howard.aris
Lee, I have made a small batch of the half time pinion nuts - if you would contact me - details on the back of cheval - we can arrange to get one to you.
Have a look on ebay just purchased a nut for my WNG NOS, enter Ariel 350 and scroll through works out £9.00 with postage.
- Leejm
I did buy one of them bit it was too big. I think it's for the axle into the flywheel not the pinion nut.
Thanks Lee I am still waiting for the nut to arrive we will have to wait and see!!!
stuart.wilby
I made one for the camshaft on VMCC members A10 out of another high tensile nut that would have been at least a 10.9, it was made a bit longer than the original nut in order to utilise more of the good threads nearer the end of the shaft, works perfectly with no issues and fitted a lot bett than a bought replacement, so my advice is to purloin a suitable nut which has the same dimensions outside, and machine the bore for the tap size, or get it screw cut if you have no left hand taps. Good luck with it.
1948 4G Square.
- Leejm
Howard made one for me. Fits great and this has enabled me to get most the bike back to together now. Still waiting for a couple of things to come to complete it. my bike is now 97 % finished.
SteveGus61
Hi, I think I might have one.
Steve
Steve
