i'm french, and i'm riding my ht5 on local trials contest.
i'm really fond of this machine, but i had serious trouble last month.
i fitted a few months ago a morgo pump.
three weeks later, during a trial contest, i had a seizure, while i was running on a track, at very low speed...curious.
then, i stripped the engine, the seizure was at the back of the piston...but nothing suspect, advance timing ok, jetting ok...
how can i test the pressure ball?
morgo recommend to remove it, mine is still here, but looks blocked, because i cannot move it, even when i use air comp trought the hole...is it normal?
does removing it requires special tools, or special tips?
in all cases, i want to congratulate you, because hte new forum is very intersting and usefull
nicolas
