My project Square Four 4F 600 1939
Re: My project Square Four 4F 600 1939
Congratulations Marco!
We expect a clip now with you zooming by on the 4F !
Eero.Korhonen
Post by Eero.Korhonen »
Hello Marco,
It is looking very good!
Br, Eero
mboelis
Post by mboelis »
Thanks.
Of course i will make a clip. When i'm at home and it is good weather, the clip will be made.
/Marco
Ariels 4F 1939 & 1940, KH 1954, NH 1954, BMW K1100LT '99, Autocom Active-PLUS, Wouxun KG-689 porto, Zumo 660, Montana 650t, GPSmap 62st, Edge 800 + CN, Security screw for Garmin Zumo 550? click here
mboelis
Post by mboelis »
Vincent.vanGinneke wrote:We expect a clip now with you zooming by on the 4F !
As requested, this afternoon after a 140 km ride
https://youtu.be/fSX-joVExYQ
https://youtu.be/5IvSIqfTIiI
/Marco
Steven.Carter
Post by Steven.Carter »
Your dog loves Ariels :D
Sounds great
roger.fellows
Post by roger.fellows »
Thanks very much Marco, hope mine sounds as quiet when I get it going.
Roger
mboelis
Post by mboelis »
yes, i hope so.
The last details
Lock the handlebar against rotation with 2 screws
New domenuts for Altette, 1.5 years on backorder in UK, last week bought from a Dutch merchant who had them in stock :o
The toolbox is ready
/Marco
mboelis
Post by mboelis »
Yesterday I bought a pail Gear Grease.
Draganfly writes These gearboxes should be filled initially with 1 ¾ lbs (800 gms) of grease or grease/oil mixture and ¼ pint (570 ml) added every 2000 miles (3200 kms).
Hmmm, short calculation: i lose 50 ml every 280 km. After 28000 is the pail with 5 kg grease empty :D
Today my friend Kees and I made two centre stands for our both 4F’s. I’m no happy with the genuine centre stand hinge construction. I investigated the centre stand of my BMW K1100 and we made the same kind of hinges as BMW. It’s working fine. No more wear on the Ariel frame anymore.
The genuine centre stand
Our centre stand
Mounted on the 4F
/Marco
steve.clarke
Post by steve.clarke »
That's a very robust looking stand Marco, were you not tempted to put on a larger foot lifting arm to assist with the weight or does it roll on the stand quite easily?
Very nice work Steve.
mboelis
Post by mboelis »
A longer foot lifting arm will bend and touch the exhaust silencer. There is on the Ariel not enough room for a good working foot lifting arm as my BMW. A longer and better version will touch the road curvy roads. I can catch the lifting arm with my boot and push it away from me while lifting the bike. It does not roll easy on the stand. You have to be strong when you use the centre stand, the bike has a weight of 199 kg without accessories. My friend makes coming week a handgrip for our bikes to lift easier.
/Marco
