1928 Model C kickstart spring
I have now tried 5 different kickstart springs, none fit or work correctly, they all appear to be too big jamming the kickstart down when starting. Can anyone advice a spring that fits and works please.
tony.barnett
Re: 1928 Model C kickstart spring
I th8ink club spares have them...but you'd need to be a member
KOBI
Velocette MAC, KSS Mk1
Thanks Tony; been a member since 2005, I've had a club spring but it doesn't work very well at all.
When you say the spring is too big is it the thickness of the material, overall diameter or width of the spring that is too big or all 3?
From memory the Original spring is only 1/4 in wide and one end is a curled bit turning on a rivet.. Nev
tony.barnett
Ok - firstly the colour of your name indicates you aren't a member - Admin should be able to sort that out.M.Bagshaw wrote: Wed Jun 24, 2026 2:32 pm Thanks Tony; been a member since 2005, I've had a club spring but it doesn't work very well at all.
Secondly - have you spoken to Geoff at Gearbox Spares? A discussion might result in a suitable spring, or at least no further poorly fitting ones.
KOBI
Always the first step if you have a problem with a parts is to talk to the supplier
The thickness & width of the spring, inc the two ends are fine, but its as though there are too many coils making the diameter too large.Roger Gwynn wrote: Wed Jun 24, 2026 3:11 pm When you say the spring is too big is it the thickness of the material, overall diameter or width of the spring that is too big or all 3?
I believe one of the springs was bought from the club, but some years ago so I don't have a record just my memory of purchase but pretty sure I did.tony.barnett wrote: Thu Jun 25, 2026 2:58 pmOk - firstly the colour of your name indicates you aren't a member - Admin should be able to sort that out.M.Bagshaw wrote: Wed Jun 24, 2026 2:32 pm Thanks Tony; been a member since 2005, I've had a club spring but it doesn't work very well at all.
tony.barnett
Speak to Geoff. He is an exceptionally helpful chap.M.Bagshaw wrote: Sun Jun 28, 2026 11:22 amThe thickness & width of the spring, inc the two ends are fine, but its as though there are too many coils making the diameter too large.Roger Gwynn wrote: Wed Jun 24, 2026 3:11 pm When you say the spring is too big is it the thickness of the material, overall diameter or width of the spring that is too big or all 3?
KOBI
