Avon tyres, lack of
Avon tyres, lack of
As Avon Road Riders are no longer available I fitted a Kenda K657 Challenger last year, on the rear, that looked very similar to the RR and handled well, the down side was that it is now worn out after 3,300 miles, the Avons would last 6-8,000 miles. I have just fitted a Dunlop Gold Seal, now made in Japan, if I remember I will let you know how that lasts. I have found before that cheap tyres do not last well, I always thought that they did not grip as well but lasted a long time due to hard rubber, not the case it would appear.
- dave.owen
Re: Avon tyres, lack of
Ive fitted a continental Go, on the back of the sq4, similar pattern to RR,
.handling good
Dave
.handling good
Dave
Ah 400x18 a wider range is available, mine is 19". Would like to fit a Conti, I used them on my Guzzi and liked them
According to my sources (Andover Norton!) Avon RoadRiders should be back in production in 2027. Dunno if they'll still be making the 19" sizes they had before though.
Andover Norton are recommending (and supplying) Heidenau K65 100/90-19 TL 57H Universal (Front or Rear) as an alternative. (This is for Commandos etc).
My airhead BM uses 19" front/18" rear and it loves Bridgestones (was BT45, now BT46). If they made a 19" rear I'd use them on the Ariel too.
The Heidenau's were my 2nd choice but more expensive than the Dunlop that my favourite dealer had in stock. I have been round the Heidenau factory, very interesting.
- markus.nikot
This year I fitted three Heidenau tyres. I usually do this myself on the workshop floor. This time, it only worked with a machine, two people and an incredible amount of effort. Somehow the wires are significantly shorter than on Avon or Barum tyres. As I wouldn’t stand a chance of repairing a puncture at the side of the road, these were the first and last Heidenau tyres I’ve ever fitted.
I’ve had good experiences with Barum; they’re just a bit soft and wear out quite quickly on the SQ4s. On the plus side, they’re cheap and easy to fit.
AOMCC German Branch Secretary
some Ariel - only Ariel
That's valuable info ! Thanks Markus.
I am informed by Mike Partridge from Waldrige Motors in Ontario, that Avon have the 20 inch Speedmaster Mk11 on thier list of tyres with expected delivery in early 2027. Apparently, he has a priority list that they have assured him will be fulfilled.
