WANTED VH500 valve lifter spindle
Simonpsmith
Post by Simonpsmith »
Mine is so worn it now won't compress the valve.
Spares not available from Draganfly.
Can anyone help?
Ideally I'd like to replace the whole mechanism.
Thanking you in advance
1933 VH500
Re: WANTED VH500 valve lifter spindle
Post by will_curry »
Simon,
Is it the shaft 335-30 that you need? Just looked at D's site where the shaft seems to be now available.
If not I'll probably have a usable one.
mark.prizeman
Post by mark.prizeman »
I've got a spare, unused, one from Drags and even though it is a bit 'clunkier' than an original, it will fit a '34 rocker box I think you have to thin down the lifter a bit
ChinniK
Post by ChinniK »
I got this https://www-arielklub-sk.translate.goog ... x_tr_hl=el from Ariel Club Slovakia for my 37’ VH500. The direction of the valve lifter arm hole is opposite but you can install your old one or leave it as is and it still works.
Simonpsmith
mine looks like this...
1933 VH500
The side valve and ohv arms are for cables entering on opposite sides
mark.prizeman
It will be the same spindle part but your rockerbox looks like this with the lifter on the side plate?
Simonpsmith
Is the spindle this one:
https://draganfly.co.uk/shop/63176/exha ... _pathway-2
and this will need attention as well:
but I'm not sure how easy to remove it?
1933 VH500
mark.prizeman
In the 33/34 parts book 335-30 is listed for side valves and 335-31 for overhead valves....
mark.prizeman
I suspect the difference between them is length? Which is crucial for your setup...
Just found another NOS spindle which even though it came with a SV arm (handed) seems identical to the old OHV one. (the repro one is longer)
