Paul - great to hear you are so close to getting your '46 on the road officially. You'll be amazed - here the law states that all the original equipment must be in working order, but there is no inspection unless the vehicle is declared a total loss by an insurance company. Because mine is built from parts that have no insurance wreck or theft claim it is already registered for the road! They still trust us to build a safe vehicle!
The pump is a new Draganfly Hawker pump. I've ordered another but they have been back-ordered for months.
With all the work on cycle parts I was also fitting fenders "mud guards" - blanks ordered from the UK a couple years ago. I wanted fenders that were slimmer and fit closer to the tires so got a C-shaped one for the front and a D-shaped one for the back to cut down. Looking to mimic this:
I had some front fender stays that needed cutting down to hold the arc of the front fender to the tire. This was very fiddly but the result is good:
Hardest part was making the fork-fender bracket. Hours were spent getting the contour and hole spacing correct but the holes line up so don't stress the brace or fender. (I've learned they can crack after some riding if poorly made)
The rear fender was far more difficult because it needed to be cut out to clear the chainguard. (The rear fender blank was full-width all along its length.) Simply cutting away part of the fender didn't seem right. I considered making a hammer form from wood and trying to peen the extra steel into a recess around the chainguard but imagined that it would pucker and dimple into trash. After talking it over with my brother the metal worker I decided to cut away the offending steel and make a patch panel. I made sure it could be made in paper before trying it in steel.
I started by cutting away all but about 1/2" of steel. It was cut with an abrasive wheel to avoid stretching and distorting the fender's shape as shears may have done. I then cut saw-teeth into the cut edge that could be folded over and welded to the patch panel.
