sliding member bushes
I Rea
Post by I Rea »
Hi after advice on removing old bushes from sliding member from plunger suspension. I could probably press them out but what size drift? Any advice appreciated and any suggestions.
dave.owen
Re: sliding member bushes
Post by dave.owen »
I cut them internally, easier to push out
Dave
Ian, I often use sockets as drifts for bushes, I don't know how easy that is for you to try (or if you've got a suitably varied selection of sockets....)
I Rea
Post by I Rea »
got them out with sockets and a vice. One question when pressing the new bushes in . Should the surfaces of the bushes and sliding member
s free from any grease/lubrication to help them in. Or should it be done dry. Thanks.
Post by JohnnyBeckett »
hi use a bit of WD 40 or similar on them and press them in or you can put them in using two big thick washers and some studying and draw them in
With bushes there and in Places like King Pins is would not matter. With crankpin tapers it's taboo. Just the oil on your skin is enough. You want it to lock and grip. Nev
