GB gearbox gear lever spline size.
dennis.t
Post by dennis.t »
I bought a gear lever on Fleabay described as: “NOS for a Burman GB gearbox suitable for Norton, BSA, Ariel, etc. With 3/4 inch spline.” Fitting it today the spline hole is too big for the shaft. Two questions. Firstly, how do you size a spline shaft, is it just the diameter across the splined surface? Secondly, on a1955 Ariel NH what should the spline size be? Lastly, does anyone have a suitable, used gear lever in serviceable condition that they are willing to sell?
Many thanks,
Dennis
1955 VH500 alloy head
1955 NH350 alloy head
Re: GB gearbox gear lever spline size.
CLAMPED splines can be a Pain if they are not tight. I wouldn't bother with an alloy one. It won't work for long. Get the right one. Life is too short. Nev
dennis.t
Post by dennis.t »
Nev,
Agreed but gear levers don’t seem to be on plentiful supply!
Dennis
Mick D
Post by Mick D »
Isn't the alloy lever the 'standard' one Nev? my 58 FH has an alloy one. On AMC machines I'm pretty sure the steel ones were only supplied on competition models.
Mick D wrote: Fri Jun 20, 2025 12:27 pm ...my 58 FH has an alloy one.
Mine too.
Post by JohnnyBeckett »
hi, my 1953/4 nh is a alloy gear lever on a GB box and i had to file the splines or teeth in the gear lever when i fitted a new gearbox shaft
Well you then don't have a lot of choice. IF it's a tight fit it will last a lot longer and being a larger dia helps. A spline really can't be adjusted by a Pinch bolt in principle. Some have the first two teeth absent. Nev
dennis.t
Post by dennis.t »
Perhaps my original post was unclear. The alloy gear lever hole is far too big for the spline; it does not even touch the splines. The lever was described as 3/4” diameter. When buying another lever what size diameter should it be?
Mick D
Post by Mick D »
Hi Dennis
I think the splines are 11/16", (that's the diameter of the shaft before forming).
hi give Geoff Brown a try the clubs gearbox and clutch spares he will tell you the size it is , he supplied me all my GB gearbox parts and a new gear liver and kickstart shaft as well
