Tips regarding rear wheel removal 1956 NH
Re: Tips regarding rear wheel removal 1956 NH
And thank you for taking the time to check your one out for me
Success, sprocket out, and the movement is easier to see
That looks OK, the spacer is there and when the spindle nut is torqued up it should clamp the bearing inner to the spindle. If the sprocket still moves it must be loose on the bearing outer or the bearing be seriously knackered. Do let us know.
Looking at the video, the shaft seems to be sliding through the bearing or the bearing is sliding through the sprocket. A video from the rear would help.
Thinking about the movement in the previous video, I wonder whether the bearing is not the correct size (too thin) or perhaps the shaft has been turning in the bearing because the bearing is seized?
I am wondering now if it’s just 4234-56 on the inside of the swinging arm that’s missing ?
Possibly, but so is mine I think. I'm sure the stub axle/spacer/bearing combo would pull up tight with that washer missing.Kevin_RSA wrote: Fri May 02, 2025 9:04 pm I am wondering now if it’s just 4234-56 on the inside of the swinging arm that’s missing ?
This has become pretty technical, so moved!
Administrator
webmaster@arielownersmcc.com
You could reassemble the stub axle and sprocket, now with the chain case out of the way, it will be much easier to see what is going on.
That will be my next task, thank youJulian Murphy wrote: Sat May 03, 2025 3:41 pm You could reassemble the stub axle and sprocket, now with the chain case out of the way, it will be much easier to see what is going on.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 6 guests
