Pre monobloc float bowl
I am in need of a pre monobloc float bowl to suit my 53 VB, it's 15 degrees, bottom feed to suit banjo and left hand I believe it's a 1BM but not sure, the one that came with the bike is a 7 degree, thanks for your time.
Kind regards Colin
EDIT
I could use a 1J which again I believe is 15 degrees and has nut and nipple bottom feed if so that could be an option if anyone has one for sale, thanks for reading
Kind regards Colin
EDIT
Re: Pre monobloc float bowl
I believe you can buy a new one from Burlen?
Hi Simon
Yes I found out I could buy one but at £175 it made me wince a little, but if it's my only option I will, thanks for the reply
Colin
Colin
- chris.shearwood
Hello Colin,
From the Amal list (2nd from the bottom of the sheet) it seems that a 1J is the correct float bowl for your 1953 VB. I have a spare one, in fairly rough shape, which I could sell for Canadian $50 plus postage if you can't drop by to pick it up.
Regards, Chris
Regards, Chris
Hi Chris
Thanks for the confirmation that 1J is what I need and thanks too for the offer of the one you have but as I am in Swansea UK dropping in wouldn't be an option, your price is reasonable but I would imagine postage would be expensive, but thanks again for the offer.
Regards Colin
Regards Colin
Set up a search on eBay. You'll see a lot of float bowls, but it worked reasonably quickly for me.
Since Chris said it's a 1J I have set up a search on ebay to find one, I was looking for a 1BM, a bottom feed with banjo, cheers Simon
Paul Gasson
Hi Colin, if you are still looking for the float bowl I found one in my spares box, it’s a 1J. A bit scruffy but should clean up and I’m in the UK. If you are interested please send a private message.
1935 RH, 1950 NH
Just to bring this advert to a close the float bowl that Paul supplied me arrived and was fitted, all good, can't than him enough,
Colin
Colin
