ariel sq four parts all sorts
p tuxworth
ariel sq four parts mostly mk1 some earlyer , i have sold my sq four and will not get another so the all the parts i have will go (i have a lot ) , tell me what you req , no dealers , still looking for B21 gearbox also
Ooh what an offer! I need lots of small things - battery carrier, footrest bar & spacer, saddle, rear number plate, tool box bracket, rear brake rod & nuts, rear light, gearbox adjuster, clutch lever pivot bolt, horn & dip switches, that stud with the two oversized nuts that holds the ignition switch, gear position indicator (both of them), the bi-starter knob...
I'm sure there is lots more! You can see some of my Mk1 on my blog.
p tuxworth
Re: ariel sq four parts all sorts
all cleaned out , did go to a dealer in the end but payed me what i wanted so carnt complain , all will be at stafford end of this month he says inc the complette engine
