Turning nipple end cable
LuisPaz
Post by LuisPaz »
A little work with my 180 x 300 lathe
Materials: Old Key
Luis, from Argentina
1944 Ariel WNG
Re: Turning nipple end cable
IF it's made from some of the high strength bronzes that have aluminium in them, it won't tin with solder. Check before you get to that stage. How do I know? Had some "Y" shaped fuel junctions cast and nothing you do will make them tin. Luckily I didn't machine all of them up before I found this out. Counter sink the thick end so you spread the cable strands so it won't pull out when you want to stop quickly. Nev
LuisPaz
Post by LuisPaz »
Hi Nev
Thanks for your recommendations and comments!
I made the solder in the nipple and it was very strong.
The decompressor works correctly with new lever.
1944 Ariel WNG
