My latest project
lawriewhite
My latest project
Post by lawriewhite »
Good morning guys ( & gals ) A newbie to this forum, but not restos, I've done many.
Just collected a 60-ish Leader, no numbers or paperwork, but it has matching engine & frame numbers, no screen or fittings & I wouldn't
buy it until I knew a screen was available, as it will look naff without!!
It will be a total nut & bolt restoration.
No rust as such anywhere, but the wheels are shot, new rims & spokes already ordered, no chain cases or panniers, so I'll have to make them.
Started 3rd kick & seems to run ok, silencers shabby but they might re-chrome, I wasn't expecting to see a plywood seat-base & thought a previous has cobbled it up, but I see they ARE like that!!
The point-cover is missing so I will need to make one of those as well
Initial findings are that its 95% there, only 1 x 3/8 x 24 screw holding each side-panel !! All in all, it seems a nice project, & there will probably
be a few questions from you experts out there, but here's one to be going on with, I found this chrome-tube with a 'handle' about 220mm long
x 12mm dia, in the frame-tube under the seat, I assumed it was a seat-release like my Bonnie, but no, it has a couple of wire 'loops' at the end,
& I can't imagine what this thing is, & I suspect i'm about to be bombarded with the answer!! :o
AndyEames
Re: My latest project
Post by AndyEames »
Somebody will jump on me if I am wrong, but isn't a lifting handle to help get it onto the main stand.
ian williams
Post by ian williams »
yes its the lifting handle, goes into the tube right next to where you have it laying .
2 tabs just under the star shaped end that twist and lock it into the "keyhole.
will also be sprung loaded so it pops out a bit when you release it .
bike looks really clean to me , one to ride as is , mine is an original 58 leader and i ride in unrestored condition albeit is not shiny and pretty in that way .
roger james "jess" can look through the records for you to tell you what factory despatch records say about its numbers , for date and where it went to and what colour it originally was if it happens to be different .
try joining the yahoo leader/arrow group , it might take a while as the site plays up , or otherwise go via the facebook page as half of the regulars are on there also and its easier to get in touch with who you need to .
nice to see another leader coming back to the roads
ian
lawriewhite
Many thanks for quick replies, & of course, its blindingly obvious now I know!! I'll have a go at pulling the wire loops in the end, its probably the
release-spring.
DavidSage
Post by DavidSage »
Gentlemen,
Sorry to use the above subject but I am trying to contact Roger. I have left a message for him on the private messages system.
Hopefully, he will reply to this note.
Once again apologies for this.
Regards,
David Sage
bh.sprint
Post by bh.sprint »
These are the bits ( just one long tube) which make up the lifting handle assembly , just need a split pin to hold the long wire in place in the top pressing tube.
Brian H.
So how does it work, as someone who hasn't bought a Leader yet?
lawriewhite
Many thanks for the photo, not sure how or what that long wire bit works though!!
I managed to source a new-old-stock neutral-switch for the gearbox on e-bay today, & its gone straight in!!
I'm assuming the switch contacts something already in the gearbox, or do I have to 'do' stuff in there as well??
New stainless rims also came, so I set about pulling the 1st hub out, nipples rusted solid so they where subjected to a 'slight' seeing to, to get at the hub, & i'll blast it tomorrow.
Thanks to Roger, I now know the bike is a 1962 & originally Ivory & black & was sold in Hazel Grove, bog standard, no extras, but it will have soon.
A new pair of Armour silencers came as well, but the studding at the exit-end was too short for the acorn-nuts to fit so I had to re-adjust it all & pull
out an extra 20mm to allow it all to work, OK now, & they are packed away again!
bh.sprint
Post by bh.sprint »
Hello,
Attached the lifting handle assembly, ready to go into the top pressing tube and be secured with a split pin. Some early models had a different long spring with prongs not eye-lets but I've heard of them coming loose.
Brian H.
lawriewhite
Thats great, I understand it now, thanks, an easy fix.
