A few months ago I noticed on my square 4 that the primary drive had a lot of slop in the mechanism and changing gear on the move was harsh
On taking off the primary cover I found the old transmission spring on the crankshaft had snapped in two.
Drags sent me replacement which I fitted, but I now notice a very jerky juddering on pulling off
Is there a way to fit these incorrectly or is the tension too tight and not allowing enough give on the cams/ spring to give a smooth take off?
Apart from that its fine but it spoils what is a good ride
Mark
Primary drive - judder on transmission
MARK.WALSH
- john.bebb
Re: Primary drive - judder on transmission
Mark - plz - having discovered your broken shaft shock absorber spring - I assume you checked the mating surfaces of the shock absorber ramps?
I suggest you view this thread http://forum.arielownersmcc.com/viewt ... f=4&t=7018 where Doug is seeking advice on an exceeingly knackered shock absorber on his 350...
I s'pose it's feasible that you have received a "wrong" replacement spring(?) - as a free standing the item (for Mk 1 & 11 Sq4 '49 thru '54) should be 1.5" uncompressed... and you should have to put CONSIDERABLE effort to compress it, even slightly, by hand.
Drags quote a different spring for the earlier 4G and also for the post '54 Mk 11 (I have no details of the variance).
I'm not aware of any tensioning for these parts- assembly is sprocket, sliding member, spring, retaining cup washer, castellated nut... tighten to torque & fit split pin.
Standard "silly" questions: - are both chains properly tensioned (with several checks at different rotations)?... are the chains & spockets all in acceptable condition? - (no links binding?)... were the cluch spring pressures suitably balanced for lift on the refit?... & assuming the vehicle was driven for a while whilst the shock absorber spring was broken... is the outer driveside main crank bearing still intact? ...perhaps the gearbox or clutch bearings require closer inspection... - yes, I know.... silly! but we all may occasionally forget!!!
HTH, cheers,
John
HTH, cheers,
John
MARK.WALSH
John
thanks for the advice I think I will have to do a thorough recheck if the problem persists
On observation on the reassembly of the bike, the cam faces were good and the spring was supplied from drags - so hopefully it is the right one. The only known backlash in the system I am aware of is the worn splines on the crankshaft (most Ariel square 4s seem to have this I think )
Ariel's are a pain in so much as having to remove all the clutch locknuts to take off the whole clutch just to get to the primary chain - I suppose its possible I could have made an error on reassembly but I will check out all you have mentioned
Thanks for the reply - something to keep me busy over the weekend
Mark
Mark
- john.bebb
Hi - Mark - yw - please - I'm not sure what Sq4 you have - note that there are x3 different springs - depending on age... it is feasible that the wrong one arrived from Drags... the little info I quoted covers ONLY '49 thru '54.
It is highly unlikely that "worn splines" should cause judder...
Hope you find the real cause!
Cheers, John
Cheers, John
Brian.Fosh
Only for info, The later shock absorber protects the splines with a splined sleeve and fits earlier crankshafts. I recall drags website explains the interchangeability.
I'm using an early rear crankshaft from an iron 4G, as yours with a lock-washer flat, on my '51 mk1 but use the later splined sleeve and shock assembly to protect the crank splines from wearing.
The earlier nut is larger A/F and its corners register within the cup that bears on the spring, but the castellated nut is smaller A/F, deeper and has a turned register on its rear that sits within I/D of the hole in the cup. After tightening up, I chose a place to drill through for a split pin that was away from the flat.
Regards,
Brian
Regards,
Brian
MARK.WALSH
Chaps
thanks again for the advice
My model is a 51 square 4, but its reassuring to hear that the problem isn't likely to be the engine splines. I might try and balance the clutch first as that is a quick and easy check. One other problem I do have is a badly worn bearing on the clutch arm fulcrum on the BA box. I did order a bearing from drags.....still waiting. I suppose this could aggravate the problem, but I wont know until the part arrives (with all the other stuff on back order)
thanks again
Mark
thanks again
Mark
