Cheers Tony
Late VH head washers
Could anybody tell me if there are any steel washers under the 5 sleeve cylinder head nuts on the late 1950's VH alloy heads please.?
Cheers Tony
Cheers Tony
Re: Late VH head washers
Taa Dave
The surfaces where the nuts sit where a bit dimpled through over tightening on mine.
I had these skimmed and bronze washers made .
Knud.Degnbol
I don't know what is original, but I would consider it bad engineering practice not to use washers. Aluminium is a soft material.
norman_john
If the studs are long enough use washers every time.
Thanks Tony
