VHA cylinder liners?
barry.krauter
Post by barry.krauter »
More than 30 years ago, I received a VHA barrel in a parts swap. The sleeve protruded below the alloy barrel, and it was broken clean off at the bottom end of the cylinder. I had the sleeve removed and determined the barrel was otherwise good. Those cylinder liners were unobtainable back then, Has the situation changed today? I did somehow obtain a VH Vacrit cylinder liner, but that's not the solution - no top lip. Any ideas?
adrie.degraaff
Re: VHA cylinder liners?
Post by adrie.degraaff »
What is the outside size?
Ian.Taylor
Post by Ian.Taylor »
I had a new liner made up for my 31 VF as well as liners for my old 32 SQ4.A good machine shop should be able to turn one up
Bob.Murphy
Post by Bob.Murphy »
I am restoring a 1931 P&M Panther 500cc. When I bought the heap of bits it was missing the barrel, however there were two 600cc barrels in the heap!
These guys bored and sleeved the 600 barrel down to 500cc. I provided a new piston and they checked the final honing dimensions with FW Thornton & Sons Ltd.
Not cheap (£207.60) but it will hopefully be OK when I finally finish the restoration ;) .
T&L Engineering (Bedford) Ltd.
Pear Tree Farm,
Wilstead Road,
Elstow, Beds,
MK42 9YG.
Tel: 01234 352418
Fax: 01234 352100
I was dealing with Barry Talbot at:
sales@tandlengineering.co.uk
They are an 'old school' Engineering company and are very helpful.
dave.owen
Post by dave.owen »
Westwood liners should be able to supply ,
Dave
In my 500 W/NG there is a liner from a tractor, done by my dad, could be Massey Ferguson, but to long ago to remember.
barry.krauter
adrie.degraaff wrote:What is the outside size?
I just measured with my digital caliper: 86.94mm at the top. The bottom 1/4 inch varies - some distortion from where the original sleeve broke off.
I suspect the previous owner broke a conrod or piston!
johnmain
Post by johnmain »
Give Roger at RTS near Gloucester a call. Top guy and should be able to sort you out
