Burman Q speedo drive
Andrew.Corbitt
Post by Andrew.Corbitt »
At the AGM I heard mention that the club were getting a batch of repair kits make for Q box speedo drives.
Does anyone know the latest situation and when they might become available?
john.mitchell
Post by john.mitchell »
This is the latest atest from Mike Taylour.
Good hunting
Editorjohn
Burman Q Box parts
Speedo spindle shaft.................................... .£14.50 inc p/p
Speedo drive gears* (sold as pair)..............£55.00 inc p/p
*You grind the old gear off the end of the layshaft to fit the new drive gear.
As I willl have some other new spares soon I will up date my list later.
Mike
See pics below
John Mitchell
kjohnson
Re: Burman Q speedo drive
Post by kjohnson »
Hi john,
After searching the forum I found this post. I have a mf350 which I am in the process of getting it back on the road, I have sorted the engine and now moved onto the gearbox, the gearbox is like new inside but the layshaft gear is badly worn and the the speedo drive gear is missing. I was wondering if you or someone would know if there is a aftermarket fix like the one mentioned here?. I have the smiths speedometer serial number but I don’t know the ratio vs gear teeth?.
All the best. Kerry.
kjohnson
Post by kjohnson »
It’s a RP gearbox :-)
john.mitchell
I don't think so but you could try Geoff our G/box guru. Details Page 2 of Cheval
John Mitchell
kjohnson
Post by kjohnson »
Ok,will do, thanks for getting back to me. Cheers!
