New member - old VB
jan.hauptman
New member - old VB
Post by jan.hauptman »
Hello everyone,
Greetings from the Czech Republic.
I recently became a member of the club, and I would like to thank you for welcoming me.
Two years ago, I was lucky enough to acquire a rigid-frame VB, 1954 model year, with valid registration documents. According to the dating certificate, the frame, engine and gearbox numbers all match the numbers recorded when the motorcycle was originally dispatched to Denmark. It arrived in the Czech Republic from Denmark in 2022. It probably did not cover many miles here before I acquired it in 2024. According to the odometer, it has covered over 60,000 km.
I have carried out some basic maintenance, including cleaning the carburettor, adjusting the valve clearances, changing the oil (SAE 50), cleaning the oil tank, replacing a leaking front fork seal, and fitting a new exhaust pipe and silencer. I have also replaced a few missing parts, such as the rear stand, battery box, horn and some other small items. My thanks go to Draganfly for their help.
The motorcycle does not smoke or consume excessive amounts of oil, and there are no significant oil leaks. The spark plug is brown. It starts well, both hot and cold. The oil pump works, although it does not seem to produce much pressure; the oil appears to circulate steadily instead. The gearbox shifts well and is quiet. The bike rides beautifully.
I have two questions.
First, am I right in assuming that rigid-frame VBs of this model year were only produced in black, and that the maroon petrol tank was simply the Danish restorer's own choice?
My second question concerns the purifier plug.
The engine was probably rebuilt at some point in the past. I suspect this because it is now assembled using non-original Allen bolts, but I have no records of the rebuild or when it might have been carried out.
I have not paid any attention to the purifier plug so far, but after reading through this forum, I am beginning to think that I should clean it. Am I right in thinking that the plug can be removed through the lower opening using a 7/16" AF socket or a modified 11 mm socket? Should it be secured in any way when refitting (Loctite or something similar)? Or would it be better not to worry about it for now and simply enjoy riding the bike? 8-)
Many thanks to you all.
paul.jameson
Re: New member - old VB
Post by paul.jameson »
Welcome to the Forum.
According to the catalogue, your bike would have been black so the maroon tank is almost certainly a previous restorer's choice.
Removing the oil purifier through the sump on an Ariel single is easy enough so I would advise doing so. You will find the plug is quite tight in the flywheel but there is no need to use loctite or similar when re-fitting it.
paul.jameson wrote: Fri Nov 20, 2026 1:12 pm Welcome to the Forum.
A few minutes with the despatch book for your year indicates that in two busy months Ariel only despatched a couple of bikes (VBs, that is) which had red tanks - about 0.5% of production. If you have a look at the dating certificate, you might see some comments in the 'remarks' column - if there is a non-standard colour it will be indicated there. PM me your frame number if you need help.
On the purifier, you might just find the plug hasn't been molested previously and the proper socket will fit. Use a decent six-sided socket on it though, they are very tight.
I just wish I had recorded what the proper size is! I think the hex is 5/16" CEI, but the thread is much bigger. This is the view through the sump plate. when you get the plug out, show us what you find!
Last edited by simon.holyfield on Fri Nov 20, 2026 9:04 pm, edited 1 time in total.
Post by Paul Slootheer »
Nice machine! I pressume your framenumber starts with prefix KW? The pictures from your bike might give a clue that The Works only made use of the later ‘round’ tank badge on the VB in it’s final year 1955 in combination with the rigid frame. Untill now I did not find any evidence about these round badges in the 1955 cataloque…
jan.hauptman
Thank you for your replies.
The certificate doesn't mention the colour, so I assume it was black.
It states the date of manufacture as October 1953. The frame number is AM (1953), while the PE engine is from 1954.
I took a photo of the plug during my last oil change (see photo). It looks undamaged. My next oil change is due in the spring, so I'll give it a go then… there's a first time for everything! :D
Hello Jan, interesting. My VB (project) dates back to 1-9-1953 and was also despatched to Denmark. It states ‘black’ for the colour. A while ago I came across a VB on this forum from the same batch and just one digit apart… :D
I doubt that the 1955 rigid framed machines had round badges as only 289 of the 1370 VBs were in the rigid frame. The fluted tank with enamel badges fools many people and according to the 1955 parts book it was still used in 1955 by omission, i.e. as no change is listed it should be the same as in 1954. The mounting bolts are in different places on the rigid/plunger fames to the s/arm ones but people do fit them.
I think the hex is 7/16" A/F, but try a 3/16 Whit socket first and if it is a bit loose use 7/16 A/F which is .037" smaller and 11mm which is another .022" smaller again.
Roger, but what about the shown pictures of my previous post and this one? Are these 1954 machines?
That is what i meant about people fitting wrong tanks, we don't know if the tanks in the pictures are correct for the bike unless you can see the fixings. They may be s/arm tanks held on by 2 bolts.
PYR 282 is on the register dated 2024 and has a 1955 frame number that is not in the despatch books.
956 UXA shown when it was for sale at Eddie' Motos was earlier advertised by Andy Tiernan who does some very good pictures. One of which shows that the tank bolts appear to be correctly placed so we can conclude that the 1955 VBs probably did indeed have round badges. https://www.andybuysbikes.com/archivehtml/07359arl.html#.
Stop press!!! I checked the drawing for the 1954 VB petrol tank and found that it is the same as the earlier rigid one except for flutes and includes a modification to the badge recess dated May 1954 to alter the badge recess for round badges. No change of part number!
E9-1520.pdf
(1.76 MiB) Downloaded 26 times
