The Norton owners club site went down for a while recently. Likewise Access Norton sustained repeated attacks. Below are some comments from the AN site on the measures taken to address the problem. Possibly a similar move to Cloudfare may help.
https://www.accessnorton.com/NortonComm ... you.42364/
You are probably right. The exact same thing happened here at AN. I fought them for weeks to keep site operating. Then in the end I had to move our dns to cloudflare and write some special mod_security rules. I also moved us to a new more powerful server. It was a nightmare, but has been okay for 3 weeks now.
In our case it was AI bots trolling the site and it was automated ddos attacks happening at the same time. Cloudflare dns has a setting to block the bots and that was an immediate improvement. When I looked at their dns the other day I noticed they had just moved their site to Cloudflare, so they will probably have to do what I did.
Since AI started up, their BOTs are mainly learning BOTs and they troll forums at a very high rate gathering info. This loads up most servers when there are hundreds of thousands of posts, and if there is another automated attack happening at the same time, like a DDOS or Synflood attack, it can become problematic. I have blocked AI BOTs from our forum and have a handle on all this. Regarding the automated DDOS attacks (or similar) they are trying to take it down or make it weak so they can then use the server to attack other servers, after they get control, which they rarely do. Your info is secure here.
AI
david.anderson
