Wanted Plunger KH Twin
Hi, I am looking to buy a plunger KH 500 twin having previous owned an NH and VH. Many thanks, Matt.
Re: Wanted Plunger KH Twin
Ok, thank you.
Unfortunately John has sold his KH.
Hello Matt, I know of a plunger KH for sale in the Netherlands, if of interest send me a PM .
I have send you a PM with the email address from the seller.
wade.edwards
The ALL ALLOY motor is a bit troublesome. I think subsequent ones reverted to an Iron Barrel due threads stripping. Nev
wade.edwards
Steel inserts are the answer.
I don't know why the factory dropped the KHA, probably for the same reason that the alloy cylinders were dropped for the road going singles, which was most likely cost. I am not aware of a problem with thread pulling on the KH, in any case the studs screw into the crankcase and the cylinder head, passing through the cylinder. There is only one central thread in the cylinder itself. The long studs continued to be used with the alloy head to the end in 1957.
