SU Carburettor
SU Carburettor
Hi all, I have brought a 1953 MKII with a Solex carburettor. I want to replace the Solex with a SU HS2 carburettor. Just wondering if anyone has done this upgrade and any tips.
david.anderson
Re: SU Carburettor
The 54 and later mk2 had a different frame (known as the dogleg frame} to accommodate the SU carburetor. The HS2 is even higher than the SU fitted standard, so it will not fit.
Re: SU Carburettor
Thanks David. Will a MC2 fit?
Re: SU Carburettor
Hi David, disregard my last comment. Any suggestions for an improved carburettor over the Solex?
Re: SU Carburettor
Why do you want to replace the Solex?
Re: SU Carburettor
Hi Simon, from what I read parts are an issue plus performnce issues.
Re: SU Carburettor
Sorry Simes not Simon, didn't have my reading glasses on
Re: SU Carburettor
This may be of interest https://draganfly.co.uk/shop/78108/conc ... t/#7500-89
Re: SU Carburettor
Simes, Simon - makes no difference!
I'd use your Solex for a bit and see what you think - mine is fine, and I am sure others will chip in. These carbs were used on thousands of (mostly french) small cars; spares are around though some are difficult like all old stuff.
I'm working on a list identifying alternative sources for these parts.
Re: SU Carburettor
I will echo what Simon Holyfield says: use the Solex. I have used Solex fitted Square Fours for around 35,000 miles and had very few problems. Perhaps the main issue can be down to wear in the butterfly spindle but a skilled machinist can bush this to restore the Solex to its initial performance. Sadly, David Jones, who used to provide this service is no longer with us but I can think of one or two people with competent model making skills who would be able to tackle the problem.
