1928 Model C kickstart spring
Posted: Fri Jun 12, 2026 3:39 pm
by M.Bagshaw
I have now tried 5 different kickstart springs, none fit or work correctly, they all appear to be too big jamming the kickstart down when starting. Can anyone advice a spring that fits and works please.
Re: 1928 Model C kickstart spring
Posted: Sat Jun 20, 2026 1:29 pm
by tony.barnett
I th8ink club spares have them...but you'd need to be a member
Posted: Wed Jun 24, 2026 2:32 pm
by M.Bagshaw
Thanks Tony; been a member since 2005, I've had a club spring but it doesn't work very well at all.
Posted: Wed Jun 24, 2026 3:11 pm
by Roger Gwynn
When you say the spring is too big is it the thickness of the material, overall diameter or width of the spring that is too big or all 3?
Posted: Thu Jun 25, 2026 7:49 am
by nevhunter
From memory the Original spring is only 1/4 in wide and one end is a curled bit turning on a rivet.. Nev
Posted: Thu Jun 25, 2026 2:58 pm
by tony.barnett
M.Bagshaw wrote: Wed Jun 24, 2026 2:32 pm
Ok - firstly the colour of your name indicates you aren't a member - Admin should be able to sort that out.
Secondly - have you spoken to Geoff at Gearbox Spares? A discussion might result in a suitable spring, or at least no further poorly fitting ones.
Posted: Thu Jun 25, 2026 3:55 pm
by Roger Gwynn
Always the first step if you have a problem with a parts is to talk to the supplier
