Honing gearbox numbers
wade.edwards
Post by wade.edwards »
Have an April 1946 BA. All good.
I get the 1BAP case code but haven’t found an explanation for the A and the M over the 3
Anything significant there?
Re: Honing gearbox numbers
They Are CASTING Numbers and show what Pattern is Used. . If it includes a date it May Be used on Models earlier than the year of Manufacture. Nev
1= shell, BAP = BA gearbox, with pivot mounting, M3 = the 3rd version of this part, frequently in Roman numerals. Ariel number is 3000-35
wade.edwards
Okay, thanks Nev and Roger. One day, no one will know these details. 😩
People say that sort of thing to me quite often, bear in mind I have spent most of the last 50 years working with Ariels as a full time job, if I haven't picked up some info on the way I must be an amoeba. Anyone can do it with a little or sometimes a lot of research. In this case look through the parts books at the 'do not use numbers'. I have compiled a cross reference list of Burman, AMC, Ariel and Panther numbers to make things quicker.
Generally cast in Numbers apply over a lot of similar Parts or Even a Part of a Pattern. Not a Lot of use to the Average collector unless you are Interested in when a design change happened We are Lucky with ARIELS with All the Information and documentation that Has Been retained. SO
ME Part Numbers show the date first Introduced but I doubt the assembly line was so Particular about what and when the Part got used. Ransome and Marles used to Make all the crankpins at one time. Is that so.?
Yes the crankpins and bearings were made by R&M although parts suppliers for other parts would vary so possibly other manufacturers were used at times. When a factory is producing several thousands of a model in a year they are unlikely to be using many left over or whatever odd parts they could find lying around, I don't really know where this often quoted idea comes from, it can't all come from the Triumph sit-in days can it, where tis certainly happened. I am not saying that there was never any cross over at the change of the year, I have a very late 1954 MKII with a steering lock on the bottom yoke and not on the frame, it is a very original bike that spent all its life in India so anything that hadn't been badged was original.
