clutch tabs - ask a stupid question.....
Alan G
Post by Alan G »
I assume these tabs are meant to be bent up to lock the bolts....?
Below is the picture of mine when I took it to bits and clearly they had just been installed as washers, not lock washers.
I plan to give then a slight bend in a vice before reassembly, so there is purchase for a hammer and drift to bend up to locate against the bolts. Or am I an idiot.....
Re: clutch tabs - ask a stupid question.....
Alan G wrote: Wed Apr 08, 2026 10:53 am I plan to give then a slight bend in a vice before reassembly, so there is purchase for a hammer and drift to bend up to locate against the bolts. Or am I an idiot.....
Exactly. They need quite a decent bend if you are to avoid trashing the paint on the clutch basket. Ask me how I know...
Now there is an interesting question, why did you paint your clutch basket, there aren't any concourse points for painted clutch baskets?
Alan G
Post by Alan G »
Roger Gwynn wrote: Wed Apr 08, 2026 11:02 am Now there is an interesting question, why did you paint your clutch basket, there aren't any concourse points for painted clutch baskets?
Wasn't me.... first time I have been in there.
It was like that when I found it Officer!
That was the one on the MK1. All my others are bare.
Chris Sealy
Post by Chris Sealy »
If you fit them as is; then mark with a felt tip pen before you bend them in the vice. You should find that careful application of a pair of pliers will avoid any paint damage. If you do make a scratch, you could always respray the whole thing after assembly.Cheers, Chris.
P.S My pressure plate is polished. Wasn't me.
Would there be a market for clutch domes with viewing slots, so you could see your glamour red clutch basket?
If you are that sad I think you could cut your own
paul.jameson
Post by paul.jameson »
A common alternative approach is to cut the original washer (which has the hole for all 6 bolts) into 3 pieces and use those as lock washers. Being the awkward individual that I am, following experience of the 6 bolts coming loose, I have drilled the heads of the bolts and used locking wire to secure them. I haven't had a bolt come loose in what must be about 50 years since I started doing this and yes, I have purchased 6 new bolts for the LG250 (current rebuild) and drilled their heads before lockwiring.
Alan G
Post by Alan G »
I am tempted to lock wire. Was thinking about doing this as those three tabs don't look very easy to work with.
