Mk1 V/V guide clearances
camstevens
Post by camstevens »
Hi All
I understand the original spec MK1 clearances are 0.002" for inlet and 0.004" outlet. I need to finish hone new Colsibro guides, but just thought it prudent to ask whether 0.004 is necessary (no point in removing material is not necessary).
I was going to use 250 grit for final finish, and a coarser grit for removal.
C
Re: Mk1 V/V guide clearances
Guides should be honed to the nominal size as the clearance is on the valve.
Chris Sealy
Post by Chris Sealy »
Hi Cam. This is from C. W. Wallers book.You can work out the max and min from the figures.
It Tells you, Just above A bit less on the Inlets will reduce oil consumption and they rarely grab when Oil s around. Not so with the exhausts. Try to have the finish good or rapid wear Happens.. Nev
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
