petrol tap thread
brian.irwin
petrol tap thread
Post by brian.irwin »
does anyone know what thread is the petrol tap ? I am currently re commissioning a leader and the fuel tap thread in the tank needs to be cleared of sealant.
Many thanks in advance, Brian Irwin
Re: petrol tap thread
Determine if it's tapered. IF it is I suspect it's a BSPT, Thread., Pretty hard to find a Die. Taps are easier A good solvent might do the Job. Paint stripper Maybe? Strong thinners Mixed with oil to slow evaporation? Nev
Pete.Silson
Post by Pete.Silson »
It is BSP (parallel not tapered). Pete
brian.irwin
Many thanks Nev and Pete, it is a parallel thread so I will maybe get a set of BSP taps in order to get the right one.
Pretty sure its 1/4, see sizes here https://draganfly.co.uk/product-categor ... aps-pipes/
brian.irwin
OK Roger thanks very much, Happy Christmas
ian williams
Post by ian williams »
yep as Roger says its 1/4" BSP on the leader and arrow .
if you put tap in and it doesnt quite line up right before it goes tight use some loctite 577 sealant on it and you can position the tap in line and the sealant will hold it in place .
the sealant sets very quickly and although sets reasonably hard it can still be undone with some effort .
ian
brian.irwin
Thanks Ian, hopefully I can clear the thread with a BSP tap,if not I will try your suggestion.
Happy Christmas, Brian.
Parallel threads usually have a shoulder to tighten onto/ against with a copper or fibre washer. Nev
brian.irwin
I am pretty sure that it is a parallel thread, thanks Nev.
