Hi All
1954 Colt recently purchased, and just going over a few things. I have noticed within a few minutes of the engine being run, the clutch us not disengaging.
Any ideas of where I need to be.
Thanks
Steve
Clutch not disengaging
Stephen Pitts
Re: Clutch not disengaging
hi it maybe the clutch plates are sticking and need cleaning with brake and clutch cleaner and adjusting
Stephen Pitts
Thanks
I'd first check anything that might make the gear change graunchy (I assume this is how the problem shows) - chain tensions and clutch adjustment for starters maybe (and whether there's the right oil in t he right places).
I'd also try to assess how easily the clutch frees when the engine isn't running - if it only frees up at the end of the lever travel and everything else is in order then you've probably got sticking (or buckled) plates (as Johnny says) .
However, while the cover is off to clean the plates it's also worth checking the pressure plate is lifting evenly.
(It's difficult to work out a condition of a clutch only working OK when the engine's not running - so most of the advice I can suggest is along the lines of 'make sure it's set up properly to begin with', which might not seem very helpful.)
(And with admin hat on, I think this qualifies as 'technical' so moved accordingly.)
Not entirely sure with the Colt but some of the C series BSA bikes have the clutch springs tighten down to a stop so no real adjustment.
It is also a fairly common mod to add a plate and lengthen the push rod.
