Huntmaster sidestand
Hi all,
Still after a sidestand for my Huntmaster if anyone has one?
Mick
Mick
Re: Huntmaster sidestand
hi Mick have you look on Ebay under Ariel parts
Yes, constantly, all there seems to be is the clamp on ones that I've not heard good things about
They do come up. Do you still have the lug on the frame?
Yes, lug is still on the frame
proper copy of original:-
https://draganfly.co.uk/shop/87390/side ... m/#2450-54
Clamp on type with a proper clamp to the frame that works, the Indians have the wrong idea about how to make it grip the tube, clamp needs to be the correct diameter and smooth not with serrations.
https://draganfly.co.uk/shop/83842/clam ... iel/#PA-36
- dave.owen
I drill and thread a hole in the back clamp and put an allan bolt in to stop it moving on the frame
hi if you have got the lug on the frame why don't you make one, or make the parts and if you cannot weld it yourself get someone to weld it up
