Square 4 heads
mike.loehr
Square 4 heads
I have several Mll square 4 heads,Question: one set has a bevel cut a along part of the flat mating block surface of all 4 combustion chambers and other sets do not have that bevel cut.Have seen pictures of the bevel cut heads also.Is this factory or modification.
- Bob.Murphy
Re: Square 4 heads
Could you post a picture or two please??
Just so we can be clear about the issue.
mike.loehr
Re: Square 4 heads
I suspect that someone has fitted high comp pistons at some point and this is to clear the piston. I have just done the same on my Traction Avant (its a car)
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 3 guests
