GB gearbox
charles.bulloch
GB gearbox
Post by charles.bulloch »
Hi, all.
Can you use semi-liquid grease in a GB gearbox and if you do can you use the level plug and drain plug?
Charlie
Re: GB gearbox
I can't see why not, although the level plug is rather small so there is likely to be a delay between the fluid reaching that level and it starting to dribble out. I would use EP90 and see little if any advantage to using semi-fluid grease
dave.owen
Re: GB gearbox
Post by dave.owen »
Grease is less likely to leak from the speedo drive
paul.jameson
Re: GB gearbox
Post by paul.jameson »
I had a 1957 NH where the previous owner had filled the GB box with grease, just the same as he had done on his earlier Ariels. It worked perfectly well.
robjameson
Re: GB gearbox
Post by robjameson »
I run semi fluid grease in both of my bikes with GB boxes, precisely because I was sick of oil leaking out of the Speedo drive. VH has done thousands of miles like that so works for me. I don’t use the level plug, I just syringe it in and occasionally squirt some oil from the can in through the filler plug.
Rob Jameson
AOMCC Member Number 4068
1957 Ariel VH
1954 Ariel KH
AOMCC Twin Spares Organiser
malcolmm
Re: GB gearbox
Post by malcolmm »
How much semi fluid grease does it take please.
Thanks Malcolm.
