My name is Jim and Im from Australia.
I have in my workshop what is suposed to be a VH 500 1949 Red Hunter..
I need to try and ID it correctly for the rebuild process.
The frame # is BX1025 and the engine # is JB2829, If it helps as well.
The bike looks like a VH but has flared front guard, Plunger rear suspention,the rear guard last 1/4 is on a hinge, The fuel tank is a rusty red, the frame is all black and the rims are chrome. What has been repainted over the years I dont know. The bike was compleat.. I didnt take any photos before I stripped her down.
The Carby is one thing that seems wrong. It has a 1'" bore and from what I can find it suposed to be 1 1/8"
The slide has a stamping of 6/4, the jet block has 301, and a main jet of 160. Is there other markings to ID this Amal carby?.
The cly bore size if I remember was 79.8mm, it has a stroke of 95mm so its suposed to be the 500cc. Have'nt found a replacement piston yet, but will bore it to STD sizing. How do I work out the type of Comp Ratio of the piston?
Im trying to strip the front forks but cant get the top cap assembly to unthread. I made a tool out of some pipe but it keeps breaking the 2 lugs on it.
Is there an other way of getting this apart? As the seals, bushes and prob the inner tubes are US.
I'll start with these questions first.
Thanks Guys
Jim.....
