Square 4 big end shells
sbeagle
Post by sbeagle »
Hopefully someone will be able to help me.
The specification for the crankshaft big end journal is 1.3745" to 1.375" (which is a very tight tolerance)
I am thinking of fitting a Morgo oil pump and I am measuring 1.370", 1.373" , 1.373" & 1.374" on the 2 crankshafts. The biggest is 4.9212 thou (1.370")
Looking at Draganfly they supply standard, 10 thou, 20 thou etc. Do I need to get the crankshaft reground to 10 thou?
Does anyone know who makes shells to suit my tolerances. I have a set of 2 thou (0.002) big end shells.
Many thanks Simon
Re: Square 4 big end shells
.0005" tolerance is pretty standard for shells, modern vehicles will have even tighter tolerances. The shells are produced to fit the sizes given and for set undersizes rather than making them to suit individual crankshafts. You should have all the journals ground to -.010" as they are all outside the limits, which will cause rapid failure. Your local automotive engineering workshop should be happy to measure the journals and advise you.
Apologies if I have misunderstood the question.
sbeagle
Post by sbeagle »
Many thanks
The next question is can someone recommend someone near Junction 11 of M25 to regrind the crankshafts?
Also does anyone have the sludge trap screws 1190-37 (I believe they are 1/4" 26 TPI BSF x 7/16" CSK)?
Regards, Simon
sbeagle wrote: Fri Apr 14, 2023 1:48 pm Many thanks
Regards, Simon
This outfit looks good, not tried them myself yet.
http://www.seager-engineering.com/
Paul Gasson
Post by Paul Gasson »
I know nothing about square fours but I saw a set of -0.002” shells on eBay earlier which the seller identified as suitable for a square four. Might be worth checking to see if they help?
1935 RH, 1950 NH
Post by Julian Murphy »
I have used Seager Eng.
Very good.
Recommended.
john.davies
Post by john.davies »
I used T & L Engineering near Bedford to do my bottom end for me including grinding and cleaning out cranks, new main bearings/ crankshaft bushes and fitting club rods with the new shells. They have a lot of experience with SQ4's as I believe the current owners father, who set up the company, had them.
Image 1931 Ariel VB31, 1935 Triumph 5/3 project, 1946 Ariel Square 4, 1952 Norton Model 7, 1953 BSA A10 Super Flash, 1954 Ariel VH
sbeagle
Post by sbeagle »
Thanks for the help and suggestions
Ian.K
Post by Ian.K »
Hi everyone
I’m after some advice please on big end bearing tolerances for a 1948 4G with cast iron cylinder block and head.
The crank rod journals are in good condition: all are round and measuring within 0.001 (1.374”) of the standard 1.375”. Good news.
I bought the new AOMCC conrods and new STD white metal shells to fit. When I fitted and tensioned up the B.E on the crank, they appeared loose. When I measured the shells they were 1.378” after tightening the big end bolts.
According to Modern Motorcycle reference (attached), clearances are meant to be 0.0005 – 0.001” (or slightly tighter), which means the standard new shells we were supplied are too big by 0.002 – 0.0025” (I have also checked with plasti-gauge). This would be an obvious cause of the play in the conrod big end and I'm worried that it would potentially cause oil pressure problems etc in the future.
Onver version of Waller (attached) says “Each bearing should be tested for diametrical clearance due to wear, and if 0.003-0.004” is exceeded, new liners should be fitted”. My 1952 version (attached) has dropped the sentence but nevertheless, I don't want to begin a rebuild at the edge of the accepted tolerance.
I know an option exists to fit -0.010” shells and grind journals but I don’t want to do this given cranks are measuring up well.
I’m turning to this forum because I am not sure what is going on. My next steps will be to measure and compare the B.E. of the new and old conrods with the new and old shells to shed some light on things.
I'd appreciate anyone's advice, particularly as to whether 0.0005 – 0.001” clearance is a reasonable expectation for a new rebuild.
Many thanks in advance.
Cheers - Ian K
Stick to the smaller clearances with whitemetal (babbit) lined shells. Get undersize, bearings and fit to rods and tension bolts .(Check crush)and bore to the shaft size plus clearance. Clean out shaft oilways by removing threaded plugs Small clearances are OK with Babbit but not with Alutin or copper lead. Nev
